Front door removal on a Sapph
I've got a new front door to fit on my sapph on the drivers side. I know you can remove them by removing the whole hinge by unbolting it but on the drivers side I can't easily get to the nuts that hold the hinge to the chassis and I had quite alot of trouble re-aligning the passenger door after I've just changed it.
Is it easy to remove the door pins to leave the bolted part of the hinge in place?
Thanks
Thanks
I know I've just changed the passenger door but the drivers door ones are more obscured and I can't be arsed to remove the dash
I have never had any luck driving out the door pins only because they are in a awkward position, even using the special tool! If you manage to get the bottom one out the top one is real pain especially if its rusty!
CheeRS, Mike
CheeRS, Mike
I had to do the passenger side and I just removed the whole hinge.
I would worry about using a punch and hammer to remove the pin.. as it might un align the hinge.
on the mustangs you just drill out the center of the pin |<---- then it breaks in half. both ends can then be pulled out. hinges on them wear out prety quick though due to the heavy doors.
TF
TF
