floor pan
unfortuantly it was life it when i got the car
ive given it abit of a tickle with the hammer but the rear foot wells are worse that the fronts, alittle past just using a hammer.
can you buy the floorpans ? see what sort of mess i can make welding one in lol
Passion for Fords!
not sure you can buy the pans,
if they are that bad ,try a portapower ram, you may have to make a frame up to push off, but they can push up to 10 tonne, almost like a small jig in effect, i use one alot for pushing door frames etc back to shape after accident damage
a good short handle club hammer does the job, when we buy salvage cars the rear footwells are always 'hilly' due to the end of the fork lift forks ending there, and going up into the floor when the car bounces up n down
either put a big pair of boots on and stamp them down, or 'tap' them with a club hammer, always works for me
Originally Posted by 155lee
paint the damaged areas to stop any rust forming,inside and underneath,put the carpets down then get it sideways and forget about hilly floorpans!just enjoy it.
looks like they used a small jack. it creased the pan. looks like you fixed it a good deal though. I agree,... just paint it and be done.
if you are keeping the carpet out it tells me that you plan on racing the car. so I wouldnt worry to much.
another option is to cut out the pan and just weld in a solid flat sheet.
TF
TF
TF
TF
Not planning on racing, but want a balls out weekend car that may see the odd track day.
The floor pans arnt that bigger problem, i just find it unsightly
155lee
06-09-2016 11:10 AM
