2wd cosworth discs road/track
Hi could anyone point me in the right direction for some front discs/pads?looking to use them round the nurburgring and road use without warping standard fitment if possible? have heard good things about tarox and national sport could anyone help thanks
The discs you mention are good, I use EBC YELLOWSTUFF, which is a track pad but works awsomely well on the road, even from cold it is perfect, little bit dusty but no noise either, I did not use the anti squeal shims supplied, and still have no noise.
You will not go wrong with these pads IMO.
A lot of discs for the Cosworths include Cosworth Tax try Rally Design who wont charge you Cosworth Tax and make very good disc and pads for a lot cheaper than most companies.
Just grooved (8), not been impressed with cross drilled disks in the past (Blackdiamond) as they crack to easily.
The grooves are sufficent to clean the pad and remove gas buildup between pad and disk, reducing brake fade.
I would highly recommend braided lines and some 5.1 fluid if you haven't got them already.
Dave
Dave
i have had ebc green stuff pads and ebc discs on my 3dr and they were crap.took the car to the ring and they didn't even last 2 laps.
i spoke to martin at reyland motorsport and he said that black diamond discs with ferodo ds2500 pads along with braided brake lines work very well so that is what i will be getting very soon
Just ordered national sport discs and ferodo pads some new type for the road,spoke to simon who said use the ds2500 for track only,seemed a really nice guy and helpfull
jason_nike
18-08-2019 10:53 AM
09-10-2015 07:38 PM
FlashRS
13
31-08-2015 06:02 PM
