sapphire 2wd.. which actuator ?
my car is as 2wd sapphire cossie spec follows..
205 block. fully re built 10k ago. it has low comp mahle pistons. hp oil pump. lightened and balanced. group a gasket. 3 bar map sensor. 803 greens. group a coil. level 8 ecu with stage 3 chip. t3 turbo hybrid with a standard actuator. running at 20 psi.
just cross looped and 4x4 tps today..
now looking at actuator which one for the above spec do i get a -31 or get a -34 in case i buy a new turbo at a later date if i do go for a bigger turbo it will most defo be a garrett gt35..
so question remains which actuator for now will a -34 work ok with the above setup or should i go for a -31 as i want to take it to msd for mapping
any help asap as i wanna purchase online tonight
I think you can use either mate - think a -31 min boost is 14psi, not sure what the -34 is. Mate used a -34 on a 4x4 running greys, MSD closed loop chip, 500 cooler and t34 with .63 housing no bother.
Only thing i've ever heard said about hte -34 is it so strong it can beak the arm off the turbo. No idea if thats true or not.
Actuators by thier nature do not have a minimum boost, they each have a range that covers different amounts.
A -31 will be fine, if in good order, a -34 is a stronger version of it, but will not snap arms off turbo's, it just has the potential to allow more boost when set that way than the -31.
thanks for all help i have ordered a collins -31 new online should arrive tomorrow. i can then book the car into msd and let stu do his magic
fitted actuator today boy does it hold boost now,, cheers guys need stu at msd now i believe he on honeymoon or something anyone know when he back ?
Tony W
09-09-2015 12:08 PM
