Help lambada sensor and closed loop msd
Old 01-09-2007, 05:32 PM
capri280
capri280's Avatar
Default Help lambada sensor and closed loop msd
need help
had to fit a auto specialists heat shield and had to make a cut cut for the lambada sensor so i removed the lambada sensor unfortunately i seperated the connector and colour taped the connecting wire
i have two items i need help with
1 two of the small nut type connectors have been lost and was wondering if it is possible to solder connect the wires
2 can anyone tell me to what wire should the yellow wire on the lambada sensor be connected to is it the black or white
help needed
thanks
eugene
Old 01-09-2007, 11:45 PM
capri280
capri280's Avatar
bttt
Old 02-09-2007, 10:39 AM
capri280
capri280's Avatar
bttt
Old 02-09-2007, 12:59 PM
NEEDFORSPEED
NEEDFORSPEED's Avatar
not sure of the colours lambda sensors normally have 2x whites a grey and a black. you can just solder them yeah but its funny wire and can be a bastard!
Old 03-09-2007, 07:59 AM
capri280
capri280's Avatar
Default nut
bttt
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
Mark RS
12-10-2015 06:01 AM
XR4
Ford XR Range
01-10-2015 12:46 PM
fordrallycar
30-09-2015 07:57 PM
stevecfrst1
30-09-2015 05:18 AM
Quick Reply: Help lambada sensor and closed loop msd
