PAS on a Cossie is it self bleeding & is it AT fluid
Just renewing the pipe from reservoir to pump as a precaution because it looks like its on its last legs,it was a non standard bit of hose that had blown up like a Johnny not suitable for oil. Will the system bleed itself with the engine running & cap off the reservoir & do i use normal ATF fluid,same as 2wd gearbox stuff. Its a 4x4 saph.
Cheers Simon.
Cheers Simon.
Originally Posted by tabetha
I just turned mine through lock to lock 3 times and it is all ok, new pipe on mine too, but end of return pipe is damp!!
cracked metal pipe where the bolt goes thru ?
SMILER258
28-09-2015 09:04 AM
Russ Payne
25-09-2015 08:29 PM
