Same oil pressure switch??
Hi guys,
Is the oil pressure switch on a Cossie the same as the one on a 2lt SOHC Pinto block?
Here in Australia 2lt SOHC's are everywhere. A lot easier to find than a YB!
Oh.. and yes I snapped the original one taking it off
Ok. Purchased a 2lt switch. Checked the thread against the old one and it is fine as mentioned. The 2lt switch is a 32psi jobbie.... I have put it on to fill the hole. This should be fine yer? Just means I will get the light on a little earlier thats all. I have another gauge in the dash any who so I can watch it there too.
Thanks again guys!!
Thanks again guys!!
Hmmm... The only marking on the switch is a 032. The number on the Cossie on is 025. I just assumed it was a presure rating. I wonder what it could be then.
