Electrical problem
Electrical problem
was driving along on Sun im the cossie (2wd ) and the battery light comes on, balls i think, then i notice the temp guage has stopped working, as has the rev counter and the fuel gauge...... when ignition is on i have no oil light or handbrake light, nor does the bulb out display work.... so im assuming its lost power for one reason or another.........
now the battery light doesnt come on at all and nor does any of the above still.
the car is defo charging and the battery is fine ( so is the fuse )
where do i start ?
cheers
where do i start ?
cheers
Have you tried the dash light adjuster on the left side of the steering column as i know if this comes unplugged the dash lights don't work not sure if it affects the rest though, but it's a start
ill tell you exactly what it is, mine done the same thing.
its fues 22 in the box it prob wont be broken but put a new one in and cleen the receving spades that should sort it.
it took me 2 days to fined it on mine
DavidK
27-09-2015 02:55 PM
Russ Payne
25-09-2015 08:29 PM
