4wd to 2wd
4wd to 2wd
alritee guys
gettin a bit bored wi 4wd,got spare motor to swap sumps ect.... always liked RWD,mega big job to convert or not too bad???
any info,help would be tops
cheers
cheers
ok,it's a escort but can give you an idea...
https://passionford.com/forum/viewto...asc&highlight=
ps: all parts for sale for 2wd conversion
Re: 4wd to 2wd
Originally Posted by rosscoe
alritee guys
cheers
cheers
I chose the easy way, which is :
1 rip out the front driveshafts (leaving the stubshafts still bolted on to hold the front hubs together), the front diff, the wanky 4x4 MT75 box+the linkage and the 4x4 propshaft. You also need to take the 4x4 starter motor out.
fit- 2wd T5 box using a special ford mount (finis code 6177696) that is £12, lines a 2wd box up in a 4x4 chassis
Speedo cable- fit a 2wd item to your clocks, and you will have to drill a hole in your gearbox mount to fit it to the T5
Fit the 2wd prop shaft.
Cut the passenger side sump bracing arm up enough to fit the 2wd starter motor. ( saves fucking around changing sumps/oil pumps/pickups.
You now have a 2wd car - you can leave the rear beam and 7" diff if you like.
But the rear beams are a straight swap, leave the trailing arms on the car, and fit a 2wd beam and 7.5" diff onto the 4x4 trailing arms, it all fits perfect. Again, if you want to save the hassle, just cut a little bit off each side of the 2wd diff casing ( just the top mount!) and it will line up fine.
Or, if you want to get involved
2wd cross member, steering rack, front hubs, brakes, 2wd sump, oil pump, pickup pipe. 2wd box, beam/ diff, prop, box, (use the special mount again)
As long as you mount the T5 correctly then you won't have major headaches
There was a smokestone saff at ford fair that had been converted to 2wd by fitting a MT75 box out of a 2.0l sierra but using the 4x4 bellhousing,never heard of this before but this must be quite straight foward, he said the 2wd MT75 box had a nice feel to it,anyone ever heard of this way of doing it ?
Simon.
Simon.
DavidK
27-09-2015 02:55 PM
Russ Payne
25-09-2015 08:29 PM
dojj
28
11-09-2015 10:00 PM
