T5 mount
Old 31-07-2007, 12:35 PM
Yura
Yura's Avatar
Default T5 mount
I have swapped engine from OHC to Cosworth 2.0 and installed it to standart OHC front crossmember, OHC engine mounts and OHC bearers. I use T5 Gearbox. Can I use for this installation mount fom gearbox Type9 (TypeN) which used with OHC engine? Sierra 3dr 1988year.
Thanks & Have a Great Day!
Old 31-07-2007, 03:55 PM
I am sure it will be similar if not the same but box mount that sits on it will be different on T5, it should be easy enough to make it fit if not though.
gcfcos
59
06-10-2015 05:04 PM
rsguy
44
29-09-2015 03:29 PM
DavidK
27-09-2015 02:55 PM
IainRS1700T
25-09-2015 06:44 AM
Andypandy260
23-09-2015 10:28 PM
Quick Reply: T5 mount
