diff mount
diff mount
Stripped the back end off me 2wd sapph to do the trailing arm bushes and it appears my diff mounting bush is split, does any one know where i can get one from and the likly cost.
If you want uprated get one of these:
http://cgi.ebay.co.uk/GGR1071-Coswor...QQcmdZViewItem
Not sure if standard ones are available new
E-Bay or traders/breakers on here for good second hand one
i recently put a ' group a' diff mount on mine. And yes imo it's deffo worth the extra cost over a standard new one. Much stiffer at the rear. When launching hard, no more that juddering of the wheels. Just rolling/spinning
diff mount
i like the sound of that group A one, Now u mention it the car used to judder when setting off i assumed it was normal
i allready had front end uniballed, stiffer enginemounts and poly bushed the rear end. But still. Those 2 big beam mounts and the diff mounts, act like a triangle, now those 3 are taken care of and feels better. (could see on the old diff hanger, (a little pointy rubber thingy rubbed in the dirt/dust) that it used play around for over 2cm's) I also did my T5 mount for a fresh one.
Note this, i use the car mainly on trackdays.
greets
greets
here's a direct link to the "group a" diff mount. these guys that make them are very active in the merkur community and are THE authority on merkur suspensions. i have one of these mounts and their poly beam bushings. my car no longer tries to swap ends when i hit the brakes. one of these will be going in the cossie sometime too.
http://www.mc2racing.com/products/xr...507/index.html
Originally Posted by dojj
them ali mounts with the poly bush inside
from yanksville u.s. of a.
as found on one of the merkur sites for soemthingl ike 25p after you convert from $ to £
also mispelt the name, rainbird as in r and b as in mike from norwich
Acutaly did I already know of m2racing but forgot there web address until now thanks you you guys
rsguy
44
29-09-2015 03:29 PM
DavidK
27-09-2015 02:55 PM
