2wd saff electric windows
anybody help me the windows on my saff stopped working last night just wondered if anyone knew where the fuse was cos they worked fine the other day now nothing looked in main fuse box but cant see any problems in there
It defo does.
It shows a WINDOW SHAPE with a arrow going up and one arrow going down.
The symbol is not very big but it IS there, but it seems to be on some cars just a front window shape with no arrows!!
FUSE 24 a 30 AMP fuse, which will be GREEN, according to my booklet, but as a cossie could be another one int he fuse box though.
Resident Wrestling Legend
99% of the time it's the actual switch which is at fault
prise it out, prise it open and look at the conctacts
make sure you do it CAREFULLY as the bits inside ping out all over the place if you don't
you'll probably find out that the pins have carbon'd up so clean them out and sorted
Cossiemodo
You may have rain leaking from the sunroof onto the switches causing them to short out, as mentioned above, open it up and have a look - worst case it's a switch from a scrapyard you need.
Have to agree with Dojj here. The Sierra window switches are known to just stop working. Had it with my own Sierra. After you poking with a multimeter I figured it was the motor. After having swapped the bloody thing over it still didn't work.
different window switches; sorted.
just checked the fuse mine seems to be a fuse on its own marked no 24 but the lid has just got caution next to it anyway the fuse was ok swapped it with another 30 amp fuse still nothing pulled the switch out seems to be ok but i was in the dark with just the interior light on will have a better look later in the week or see if i can get hold of another switch but that might be not that easy with not many kicking around cheers for the advice boys
They are the same as any 4 door sierra, pm me if you have trouble getting one.
I would be checking at the switch for power next, one live one earth, disconnect the switch to check this at the terminals.
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
