rear trailing arm
rear trailing arm
Just found out one of my trailing arm bushes has buggerd up, does any one have any advice on changeing em, wheres the best place to get em from i was thinking of poly bushes. or would it be easier to buy new arms or standard bushes.
Yep, have had that experience ...
Had to replace bushes on both trailing arms ... took me about a week of evenings after work to get the old bearings out ...
Had to cut them out bit by bit with a hack saw, and then hammer and cold chisel them out ... tiring and long job.
Replaced them with polys ..
Have fun
Have fun
Originally Posted by Moonstone Mart
My trailing arm bushes/bearings were totally worn out so i changed them to poly bushes.
I stripped the rear beam off and got the arms in the press at work..they slid out a treat
Mart
Mart
i had a coont of a job gettn the bastards out, had to cut the rubber away
from them so i had something solid to push against in the press, after doing that i put the trailing arm in the press only to find it was to big
to get in there
so i ended up using two sockets the right size,put it in a big bench
vice an swung off a big peice of pipe to get them to pop out
what a mission, really hope i never have to do it again.
dont use the oe bushes get some powerflex polybushes, much better.
and for advice on changing them, i hope you have big muscles in your arms lol, just stick at it till ya get em out
Resident Wrestling Legend
Re: rear trailing arm
and, if you are going to do one side, do the other side as well because it saves loads of hassle
also worth shelling out for some braided hoses for the rear and flushing the system, you've got to bleed the brakes anyway so you might as well do the whole rear end in one go
bushes
Not looking forward to that then But ill have to have a go. Once the old ones are out is it quite easy to put new ones in, also ive seen somewhere that sells poly bushes and it says sold in pairs, does that mean a pair for one side meaning ill need 2 pairs?
i think there are 2 sizes on the rears, but don't quote me on that one
the pair may also mean the 2 seperate parts as they slip in from either side rather than get pushed through the middle like the oe bushes do
price is also a big factor, powerflex is what i'd go for but deflex also do them for about a 10th of the price
i've got a whole rear end sitting in the garage from deflex if you want
all you want is a rear trailing arm inner kit and a rear trailing arm outer
kit. comes with 2 sets of each in each kit, s/s sleaves,nuts an bolts an grease, what ever you do, DO NOT FORGET to put the grease on them.
as for fitting them still waiting for my rear end to come back from powder coating, but il let ya know if i get mine in before yours lol.
i even have part numbers here sitting in front of me lol.
inner kit PFR19-111
outer kit PFR19-110
these numbers are for powerflex ive course
inner kit PFR19-111
outer kit PFR19-110
trailing arm bushes
just found a shop on ebay thats selling em for 90 Quid for the complete set. Both sides inner and outer. Time to get the old spanners out me thinks
Originally Posted by Nash
Standard Bushs are better as they are rose joints, Getting them is difficult now though. I am in the same boat with one on mine thats not in the best of health.
Fudgey
17-09-2015 01:06 PM
Tony W
09-09-2015 12:08 PM
