Temp problem with 2wd Saph
Right all started the other day been out in the car temp was fine never really past half way on the gauge got home and parked up with engine running for a fer mins. all of a sudden the temp gauge shot up so turned engine straight off as i did this steam came out the water bottle
looked under bonnet and i had a split hose got a new hose problem solved or so i thought
filled back up with water etc and started her up all fine left running for bout 10mins still fine temp gauge fine etc thought i would drive round the block got to the end of the road and temp gauge went off the scale and when i say off the scale i mean off the scale
Turned engine off and it stayed there after a few mins the gauge drops well past the lowest mark
Checked under bonnet wasnt really hot and water was fairly cool ?? no sign of overheating
anyone any ideas as i dont wanna drive it gauge was working fine before the split hose episode
any help would be great
The temp gauge wire is shorting out onto the body giving a false reading, had the same with mine. I cut the end of and crimped a 'BLUE' bullet connector onto the wire, works fine. Worth replacing the switch while your there, be carefull as they can snap off !!!
FlashRS
13
31-08-2015 06:02 PM
Harryh24
26-08-2015 07:50 PM
155lee
14-08-2015 11:21 AM
