Got Stg 3 Greens etc, WANT to go Greys
Cossiemodo
Got T34.63, which on Greens, 3bar, 500i/c etc. is a bit laggy. So, either I go for .48 or .55 housing to reduce lag and make the most of the car as it is, OR I keep the .63 housing and go for more power - no guesses which route I'm favouring most
So, to go with Greys, I need of course Greys, plus what, just new chip to suit greys and standard compression?
Live long and prosper!!
Originally Posted by cossie4i
You will need valve cutouts in the pistons to fit a BD14 cam
Steve.
Steve.
If you have a near std head and use a triple layer gasket you can get away with it, you will have to dummy build to check for clearances first..
BUT when doing this way on std springs keep the rev limit to under 7k
It is better to use cut outs as Steve says, but there are many users on here with BD14 inlet cam and no cut outs
One guy on here has just over 400 bhp on greys using BD 10's
07-10-2015 12:56 PM
