Valve stem clearance in bronze guide
Old 21-06-2007, 04:17 AM
Souleyman
Souleyman's Avatar
Default Valve stem clearance in bronze guide
Hi, mates.
What can be the clearance of inlet and exhaust valve stems in bronze guides?
I saw in workshop manual the std clearance with std guides:
in - 0.03mm
ex - 0.055mm
It seems too large especially on exhaust valves. Isn't it?
And with the bronze guides the same clearances will be true or they can be some smaller?
Old 21-06-2007, 05:49 AM
Exhaust has most likely got more clearance as they are hotter and expand more.
I would say the clearance is the same with BRONZE guides.
Old 21-06-2007, 06:15 AM
Souleyman
Souleyman's Avatar
Thanx!
Old 12-12-2008, 10:04 AM
Yura
Yura's Avatar
The original guides is not bronze??
01-11-2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
17-10-2015 10:32 PM
DAZZER
30-09-2015 08:43 PM
fordrallycar
30-09-2015 07:57 PM
RS-Rikki
21-09-2015 07:27 AM
Quick Reply: Valve stem clearance in bronze guide
