is this an rs 500 intercooler(pics)
and are they any good? and how much are they new? ill be fitting it under my radiator on my mk5 van thats fitted with an rs turbo engine thats running 1 bar boost
As said standard 2wd intercooler.
The RS500 type is easy to identify as said it is BIGGER than the main rad, and bolts onto the chassis rails just like the main rad does, in front of it, then the two inlet outlet pipes point out above the main rad, and are about 8/9" long.
thanks guys, it was in the back of an old van i braught, theres also some 4 pot calipers and discs, i have no idear if they will fit my mk 5 van yet
Offer them up with 4x4 cossie discs 273mmx24mm, and I think you will find they go straight on, just need to tap the lug hole, which conveniently is already the right size!!
JK12
33
26-04-2021 12:09 PM
3doorcozmess
20-09-2015 06:15 PM
