4x4 wobble
Old 14-06-2007, 10:07 AM
Smoker
Smoker's Avatar
Default 4x4 wobble
seem to have a problem with my 4x4,when i accelerate hard the engine vibrates like mad,im also geting a clonk sound from both front wheels and when cornering left the o/s wheel feels like its going to fall off,the tyre also cathes the arch. i have changed the 2 engine mounts to collins items but still not solved the problem,its fully poly bushed so dont think it could be any bushes? well any one that can point me in the right direction,will be much appreciated, once again many thanks for looking
Old 14-06-2007, 05:39 PM
TurboShed
Cossiemodo
TurboShed's Avatar
What wheel and tyre sizes have you got fitted?
Old 14-06-2007, 06:05 PM
cossiechuckie
cossiechuckie's Avatar
had the same sort of problem on mine a while back and it was the driveshaft. The inner joint bearings had started to break up, new driveshaft and it was good as new
Old 14-06-2007, 09:07 PM
cameron2
cameron2's Avatar
Mine did this and it was a fucked hub. The wheel bearing collapsed due to the hub being very worn.
Old 15-06-2007, 11:57 AM
Smoker
Smoker's Avatar
Default 4x4
i have esc cossy wheels on 215/45/16 tyres,its had a new shaft put in and a new hub
Old 15-06-2007, 03:51 PM
TurboShed
Cossiemodo
TurboShed's Avatar
Balljoints ok??
Old 15-06-2007, 06:48 PM
saff cosworth
saff cosworth's Avatar
try changing the wheels around. see if that works
Old 16-06-2007, 08:33 AM
Smoker
Smoker's Avatar
_________________
experienced that just before this problem
Old 20-06-2007, 02:42 PM
Smoker
Smoker's Avatar
Default sorted!
it was a wonky driveshaft,bent it up after my wheel bearing collapsed and then i tried to drive it. now sorted so thanks guys n girls
01-11-2015 06:53 PM
07-10-2015 12:56 PM
gcfcos
59
06-10-2015 05:04 PM
Iain Mac
30-09-2015 09:39 PM
cossie330
27-09-2015 04:13 PM
Quick Reply: 4x4 wobble
