water cooling on t3 turbo
hi
i sure it has already been covered , but i would like to know if any of you are running a t3 with out the watercooling pipes connected, and if its ok or not for the turbo , im allso thinking of fitting an oil cooler to keep temp in check , so am i right in thinking i would do away with the modine cooler if i fitted one ??
cheers for any advice
ant
ant
T3 will be OK without water cooling.
Remove the modine if you fit an oil cooler - but you'll either have to join the original 2 water pipes together, or get some replacement pipework to replicate the original routing (but now from the heater matrix straight to the back of the head).
cheers for that , i already have a cooler and take off plate from an old pinto , it has nt got a stat ,so do i need a new take off plate with one built in or just an inline one ?
thanks ant
thanks ant
Ford Focus RS Parts for Sale.
02-06-2016 06:46 PM
09-10-2015 07:38 PM
Matt Baxter
16-09-2015 08:30 PM
19-08-2015 06:25 PM
