Lower wishbone length issues
Old 08-06-2007, 02:35 PM
TurboShed
Cossiemodo
TurboShed's Avatar
Default Lower wishbone length issues
Apparently the aftermarket lower wishbones on my 4x4 Saff are too long, and that's what's causing my F/OS wheel to rub on the sping platform of the Koni shock on hard left cornering.
Does anyone know anything about lower wishbones, length differences - aftermarket/4x4/RWD etc.
Old 08-06-2007, 03:04 PM
jon@work
jon@work's Avatar
the length of the TCA will not have any effect on clearance between the tyre and the spring seat - either the wheels are the wrong offset, or your wheel bearing is loose, or the strut/hub carrier is bent
Old 09-06-2007, 05:34 PM
TurboShed
Cossiemodo
TurboShed's Avatar
I'll take a photo when I get a moment, but if I was to say that the camber of the front wheels looks WAY wrong, ie. the front wheels lean inwards visibly at the top compared to the rears, would that make sense??
Old 09-06-2007, 05:44 PM
kjc300
kjc300's Avatar
I would say that the wheel bearing is on it's way out/gone - OR the nut has come loose. That would allow the wheel to do that!!
Jack it up and give the wheel a shake
Old 09-06-2007, 05:58 PM
TurboShed
Cossiemodo
TurboShed's Avatar
I've had both wheel bearings replaced recently.
Old 10-06-2007, 09:13 AM
dojj
Resident Wrestling Legend
dojj's Avatar
sounds like you've got one from a granada
they are iirc 12mm longer than the sierra ones
if the camber is out then that would be the first port of call
also, assuming you've got cossie ones in there, there is also the issue of the cossie useing M12 bolts rather than the M10's of the other versions so if you had the other ones fitted you've have to swap the buhes over in the first palce
Old 10-06-2007, 12:21 PM
TurboShed
Cossiemodo
TurboShed's Avatar
Ok a couple of pics, hard to see but if you compare the angle of the front wheel and the rear wheel on each side...
Old 10-06-2007, 12:32 PM
dojj
dojj's Avatar
looks like the offset of the rims is wrong, they seem to be way to far in compared to normal rims
then agian, i may be worng
Old 10-06-2007, 12:46 PM
TurboShed
Cossiemodo
TurboShed's Avatar
I think it's just those pics that make it look like that, try this pic:
Old 10-06-2007, 02:03 PM
dojj
dojj's Avatar
what you want to do is take a pic from ground level, preferable from below the fog light level to sow the camber differences between front and rear wheels
Mark_
14
16-01-2016 05:27 PM
01-11-2015 06:53 PM
Chas
05-10-2015 07:13 PM
Fudgey
21
30-09-2015 06:19 PM
SMILER258
28-09-2015 09:04 AM
Quick Reply: Lower wishbone length issues
