wheel sizing
wheel sizing
hi
what is the stud pattern on a sierra sapphire i no it is either 4 x 100 or 4 x 108 could some one confirm this.
also what would be a good offset when buying a set of 17" alloys.
also what internal diameter should i look for.
thanks hope you can answer my questions i know they are simple but make all the difference.
4 x 108 is what you need.
With regards offset, this is dependant on the wheel width, not the diameter, but something around 33 - 38mm would be in the right ball park for a 7 - 7.5 inch rim.
internal diameter ? if you mean the spigot size that the wheel sits over, then the hub central diameter is 63.5mm.
Adam Graham
06-09-2015 06:04 AM
3dr cossie
Alloy wheels and ICE for sale
02-09-2015 08:58 PM
