Can't get my left hand front driveshaft back in
I took my LHF drive shaft out on my 4x4 Cossie and fitted some Powerflex bushes at the same time, boy what a job, now I have come to put back the drive shaft and cannot compress the spring, inside the inner CV joint, enough to locate the lower ball joint into the spindle carrier. Is it me just being a wimp or has something changed to stop me doing it
If Dojj's suggestion doesn't work then maybe this may help ?
http://forum.fordsierraclub.co.uk/viewtopic.php?t=10501
I used a ratchet strap for tension and a small length of wood to twist the strap and pull the wheels together. Dunno if that's any use
TCA bushes
track.focus'd
12-08-2015 05:53 PM
