pace cooler and rad
pace cooler and rad
i got a pace 500 intercooler and radiator just wondering if anybody come up with any good ideas for brackets to support the top of rad stop it flaapping around been told by nms that eventually the rubber bobbins spit and rad will fall out
I have similar problem I have two forge items and there not the best fit with one another and tended to flap about somewhat, I have just taken them out and given them to an alloy fabricator to change the brackets and make them sit together better
brackets
get ya self 2 L brackets and drill a ten mill hole in 1 end , un do the 2 top bolts that hold the fans to the rad, fix the brackets to the bolts that hold the fans to the rad.push the L bit of the bracket up to meet the under neath of the 500 cooler outlet pipe,and then put a jublly cilp a round the 500 cooler out let and tigten with the L bit of the bracket in between the cooler pipe and the jublly clip then jobs a good en
ITS fitted right karl norris had a look and said would be best to support with brackets they had got a 3dr in there on wednesday whilst i was having remap and the rad had fallen out jammed under the wheel and caused an accident
so just for extra safety im going to make some brackets from the top of the rad to the front cross member
The Youth.
30-09-2015 09:59 PM
