Does anyone know the answer to this? PLEASE!!!
Right, i've got a 4x4 cosworth with a ahmed bayjoo stage three chip which was fitted by Harvey Gibbs by previous owner.
It has a switch for high/low boost.
My problem is that it works fine when on low, but on high it doesn't boost to what it used to and stutters. It boosts up no problem with a bleed valve attached instead of the amal, which has led me to think it is something to do with the amal/amal wiring. I have checked the amal function and this is fine.
I have figured out that the switch breaks the earth which goes to the amal valve. Now this is where my problem starts. The wire which usually goes to the amal from the ECU (brown with yellow tracer) has been cut and the switch inserted here, but only the end going to the amal! - The other end is not attached to anything - The output from the switch is attached to a thicker brown wire which is part of the original harness for the ECU but cannot see where this goes or where the other end would have gone.
Surely this must go to something which controls the switching of the amal to control the boost, but where? Why has this been done and the ECU bypassed. I find this really strange! What could be done on the other end of this wire, as i'm assuming this is what's at fault Could i just connect it back to the ECU?
If anybody has any experience of this then i'd love to hear your responses as i hate using a bleed valve.
Thanks in advance.
Pete.
Thanks in advance.
Pete.
rsguy
44
29-09-2015 03:29 PM
