Question about headcylinders
Maybe Offtopic -
If I switch a headcylinder with 8v from sierra with an 16v headcylinder from Mondeo(same engine block), will i need other ECU? Is timing the same? Will injectors time of apperture modify(i mean it needs to be modified)?
Thank u. I hope u wont get angry for being offtopic.
If you switch any head from 8 valve to 16 valve ALL the characteristics such as FUELLING and TIMING change, due to the fact that the air speed has changed and therfore the cylinder filling.
