original t3 4x4 turbo max boost
Hi there! What the maximum boost can hold up the stock 4x4 T3 Saph turbo without any problems and so on?
It can be set up to 22psi, my original 2wd T3 was, just that with the standard bearing life would be reduced, but by how much is subjective, as it depends how the car is driven, I just opted for a 360deg bearing to be fitted before I get it checked over after the engine build,
Originally Posted by tabetha
T34 way better, just get 360 and step gap seal at same time.
The turbocentre 01924 404112, ask for ANDY or CRAIG.
Unfortunately is not so easy to call the Turbocenter from Russia.
I try to talk with our turbo-rebuilders, but all of them prefer the modern GT ball bearings turbos and don't like to work with old T-series.
But for installing the GT2871R or GT3071RWG needed too much modifications...
Or I'll try to write to Andy and Craig to sail me the ready to use cartrige or another needed parts...
Originally Posted by simonc
I blew 2 T3 turbo's @ 1.5 bar in a matter of weeks on my Cossie, in the end it worked out cheaper to get a T34 in the long run.
Simon.
Simon.
1st turbo held 22psi and went bang
2nd turbo held 18psi and went bang
so i got a T35 instead
Matt Baxter
16-09-2015 08:30 PM
