rocker breather threaded fitting, what size?
I took my powdercoated rocker cover to be machined today but they said they couldnt do it due to the bailey breather pipe sticking up.
So I thought that perhaps I should get it treaded and a goodridge fitting put in instead. Has anyone done this before if so what size and thread type did you get done?
John
John
mine is getting done by my engine rebuilder so i not sure on what size hes doing it to but, if you buy the fitting, you are going to match it to
your breather hose etc right. so you would want to drill an tap a hole
for the correct size and thread of that goodridge fitting you intened to screw into your rocker cover. get what i mean
Thanks guys,
Yes see what your saying Dox, I guess I just need to measure the hole from under the cover and then buy a fitting slighly larger then get it treaded to the fitting type and size.. I was going to use the standard Spec-R breather pipe I have which I think is a -10.. any one know for sure?
Originally Posted by rsnissan
I used -12 for mine which is pretty fooking big not sure what the thread is though
JoeyBoyden
18-08-2015 10:52 PM
