als question
als question
read stu's thread about modding the l8 ecu to do als but what other parts are required? i know the turbo needs a maram shaft or eqivalent but what else pls? and once done can it be switch on/off as far as i know it is illegal for road use any help would be great thanks
cheers graham
cheers graham
You will need a modded iscv and depending how aggresive you want anti lag you will also need a modded throttle body, Watch the post in general discussion over the next few days as there are a few more bits and pieces coming together (hopefully) for this conversion that may be of interest
Steve
Steve
Testing the future
it has to be switched on by a switch, and can be switched off again. when off, ecu runs normal maps.
apparently, if you don't run the als with a very aggressive strategy, then a maram shaft is not needed - but don't take my word for it
