ABS sensor problem.... Help please asap
My ABS light has come on on my 2wd saff, does anyone have any tips or a quick method of finding out where the problem is. I know i could swap each sensor out but i was just wondering if theres a easy way.
Thanks all
Thanks all
you could pull them out an give em a clean as they get heaps of greasey
shit over them, which blocks the signal it reads from the abs ring or something it worked for me
in the past, worth doing as it cost ya nothing to start with, hopefully that
may fix it for ya.
may fix it for ya.
abs light
had the same prob on my 4x4 took the sensor out the hub(was covered in greasy shite!) cleaned em up well 1 acutually the other was jammed in! the light has gone out but i still get a kick back on the pedal. also check the conectors to see if they are intact.
Received 1,042 Likes
If u can get hold of a multi meter. If u disconnect the abs sensors 1 at a time n u can check for resistance in the abs sensor. If u dont have any resistance the sensor is nackered. U can also jack the car up n spin the wheels check the sensors 2 c if they r creating a voltage at the sensor connector so u know that they r workin ok n there is on dirt or damage 2 ur abs teeth on ur drive shafts.
Re: abs light
it supposed to do that
Re: abs
should it do that even when you drive normal? the pedal goes rock hard and i have no brakes! defo thats not normal? eh dox?
and there is no mechcanical problem with any ther parts of the
braking system. i would have the abs ecu checked out aswell as the
abs pump/motor
