Whats the best position in a Saph boot to mount a CD changer
Just bought a Kenwood 10 disc boot changer & head unit off of e-bay, have fitted it all up & got the changer just sitting on the boot floor.
Whats the best place to mount it ? As the small plastic brackets that come with the unit don't allow you to bolt to the underside of the parcel shelf where i would like to put it unless you put the unit upside down !
Hopefully i should have this 400bhp beast on the road soon once i've done all these little jobs.
Cheers Simon.
Cheers Simon.
Are you sure about the brackets not allowing this "upside down" mounting ?
All the kenwoods I have had you could swap the brackets over from end to end , side to side to enable this as this is where mine is mounted.
Ye have mounted it ok now as like you say the brackets can go in several positions but only held on by one screw either side now as their is only one way the bracket goes on with 2 screws either side & that is no good for fitting it under shelf. All done though & now under shelf.
Thanks for the help.
Simon.
Simon.
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
chris m1
07-09-2015 08:02 PM
