Wheel alignment on 4x4 Saff
Can anyone help me with settings for toe in/ toe out ,KPI and camber front and rear as nobody has even heard of a cossie in Canada let alone got any specs.
HI bud we have 4 wheel lazer alignement machine at work, if you give me a day or two till im back at work ill print the specs out and post them on here for you
Hi,
Ford Motor Sport recommandation Sierra Sapphire Cosworth grN Tarmac, was (in 1990, long long way)
Front
TOE in : 2 mm.
Camber : 2° negative
Castor : 4°
Rear
TOE in : 2 mm.
Camber : 1° negative
I think it is very similar of stock vehicle.
Regards.
Claude
Front
TOE in : 2 mm.
Castor : 4°
Rear
TOE in : 2 mm.
Regards.
Claude
steerfromdarear
28
29-01-2016 06:14 PM
mrmann
20-08-2015 11:24 PM
