Upgrading from T3 to T34, need some advice
My 2wd cossie is running stage 2 on dark greens etc with a bayjoo chip and on a standard T3 turbo. I am upgrading to a T34 with a .63 housing.
Would I need to adjust the fuel mixture or change injectors, or would it be best to get it setup by a professional? If the latter, has anyone had experience with "Engine Advantages" in Whitham?
ok then i will change the turbo and take it straight down to [ea] to get set up. would they do away with my bayjoo chip and write their own chip to suit if so is there any disadvantages in this also is this likely to be expensive, cheers
rsguy
44
29-09-2015 03:29 PM
