Analysis of compression test???
Old 19-04-2007, 01:41 PM
cosrep
cosrep's Avatar
Default Analysis of compression test???
The car is question is my friends 2wd saff, it has 126,000 on the clock, the tappets are a bit noisey and when revved you can see white/grey smoke from the exhaust. As far as I know the compression pressure should be 8.5 bar. I let the car reach normal working temp, then took each plug out in sequence and inspected it and down inside the cylinder with a torch before carrying out the compression test.
Cylinder 1:
Plug - Black, wet looking
Piston - Black, wet looking
CP - 10.8 Bar
Cylinder 2:
Plug - Black/brown, dry looking
Piston - Black, dry looking
CP - 10.9 Bar
Cylinder 3:
CP - 10.2 Bar
Cylinder 4:
CP - 10.5 Bar
Old 19-04-2007, 05:29 PM
Good for the miles.
Old 19-04-2007, 07:41 PM
cosrep
cosrep's Avatar
Yeah I was expecting worse to be honest, but surly the excess pressure (over 2 bar in some cylinders) must be caused by somthing. I was expecting to see lower compression pressure than It should be due to bore wear. Perhap the worn tappets are allowing excessive valve clearance or worn guides/seals are allowing oil to leak into the cylinders.
Old 19-04-2007, 07:55 PM
Confused excess pressure over 2 bar, please expand a little.
Old 19-04-2007, 08:07 PM
cosrep
cosrep's Avatar
According to Autodata the compression pressure should be 8.5 bar and some of the cylinders have more than 2 bar in excess of this.
TPM961
15-01-2018 10:50 AM
Prickly_buzz
07-12-2017 09:52 PM
tankybaby66
06-02-2016 02:24 PM
01-11-2015 06:53 PM
Fezman1
02-10-2015 01:22 PM
Quick Reply: Analysis of compression test???
