Cossie 4x4 oil leak
Received 1,042 Likes
Cossie 4x4 oil leak
Since i put my new engine oil in silklone 10/50 my engine is leakin oil around the sump area. Its not the sump drain bolt cause its new and the washer is new.Think i might have 2 have a better look n c where its coming from.
Well ive always had 1 on mine ive changed the oil 3 times in the year ive had it.there is oil droplets on the bottom of the sump n on the anti roll bar.Ive checked my oil level this morning n its between the full n low mark.
Should definitely have a sump plug washer, I think the new ones have an integral washer. I've had a few different ones from Ford!![/i]
I would use a washer if even if ford did not ?
I also coat the threads and washer area with sealant LOCTITE 5910, and it does not ever leak a single drop then!!
I lacked the car up this afternoon cleaned the sump off ran the engine till it got warm n just watched switched engine off.I can see a small trace of engine oil trickeling down from the sump bung washer n onto the side of the sump.What type me washer do people use.The one thats on now is a white washer n when its tightened up the washer spreads.
they dont normally have washers but wear where sump plug sits obviously everytime you tighten it, so best with one. either white nylon one or copper makes no odds and if the threads are good and its tight it shouldnt leak!!
Well ive put a copper 1 on n fingers crossed it looks dry still the nylon washer what was on looked squashed n out of shape n didnt look like it was sealing the bolt.
Well my car has been stud a week due 2 not driving it cause of my dodgey wheel bearing so i thought i wud start the engine this morning.I had a quick look underneath n there is still a few patches of oil on the floor again.Its doing my head in now.
its not coming for the sump bung.There is droplets of oil on the bottom of the sump n i have 2 patches of oil on my drive.im gonna have to have another look at it.Just carnt see much cause of the sub frame.How hard is it to take the sump off.looks like a bit of a pain,drive shafts out n front diff off.
Well i was gonna have a look tonight after i got my front hub off n went 2 start the car n it wouldn.t start think fuel pump might not b workin i can here n feel the yellow relay workin.
JoeyBoyden
18-08-2015 10:52 PM
st220kyle
16
14-08-2015 06:13 AM
