Turbo identifcation?
T3 is tiny....t34 is bigger...and T4 is even BIGGER
Comparing the t3 to the t34/35 from the 4x4 range, the t34/35 has a mounting lug for the actuator cast into the compressor housing on the left as you look at it. The T4 has the actuator in the same place as a little T3 but is obvisouly much larger visualy compared to either of the other two.
Actualy, if you go thru my restoration pics you'll see a pick of a t35 fitted to my engine when i dropped the engine back into the bay, then furthur down you'll see the T4 ive fitted...compare the turbo size difference in those pics m8. Click on the link.
http://bbs.rsownersclub.co.uk/showthread.php?t=103652
JK12
33
26-04-2021 12:09 PM
