Rear brake upgrade
Handbrakes are for poofs.
Hydraulic with all new stainless steel lines through entire car.
The handbrake does have a thing to hold it so if you're on a hill and need to get out of the car but want to leave it running.
looks well, you just bought the wilwoods and made up your own brackets, or do they come as a direct replacement? what disc dimensions do have there btw?
regards,
regards,
Not sure what MOT requirement is for handbrakes. I'm in the US. But here's a pic of the handbrake I am using. Note it has a parking brake type option. But there is no option for a cable engaged parking brake.
http://www.ksportusa.com/products/ebrake.html
The rotors are 282.575 mm (11.125") by 21.971 mm (0.865"). Off the shelf circle track part here in the states. 4X 1.125" piston NDL caliper
Front are 285mmX25.4mm. 4 X 1.62" caliper FSL caliper.
Dual master setup with 0.70 and 0.75" master's.
We have a fairly easy to pass biannual emissions test in Colorado and that is about it.
Brake balance will be via a dual master cylinder setup. Custom bracket and modified bell. US cars all had rear drums as well.
End result is nearly identical braking force (theoretical numbers) to the Group A Escort WRC cars with only a slight increase in input force (73 lbs. vs. 70 lbs.) Actual result will be tested in a few months.
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
