clutch and throttle cable replacement
ok my throttle cable snapped on me and the clutch is stretched so goin to replace both how easy is it to do on a driveway with jack axle stands etc??? any particular technic?? my mate who works for ford is goin to do it but hes never done them on a saph cossie before. its a 4x4 if it makes any difference
cheers
daz
cheers
daz
More boost Igor!
The pedal part of the throttle cable is covered in the Sierra Haynes comic
The throttle body part of the cable is simple - I've taken mine off several times, just don't lose the clip that holds the cable on the linkage!
And, I think you'll find that the clutch cable's the same as the MT75 procedure in the Haynes comic - closest match would be in the red XR4x4 Sierra comic - I'll lend it you when I see you on Saturday
Easy one man job, just malke sure you attach the bearbox end first, then when you PUSH the RATCHET ADJUSTER FORWARDS it disengages the holding pawl, and then just push all the way and simply slip cable in, let go and a few pumps of pedal to adjust.
you guys are tops!!!
do either of you to great libraries of knowledge that u are know the routing of the clutch cable or where it clips in out etc??? cause from the top its like a mystery maze. is it really that simple to replaxce as u say??
cheers
daz
cheers
daz
Yes easy as that, don't know the routing of the 4bee one as mine 2wd, but if cable on nearside of box wil be the same, passes under front of the engine and on top of the cross member, if I remember right.
mike elsome
14-09-2015 04:08 PM
