head bolts...
head bolts...
needed asap the correct torque settings for head bolts on a 2wd sapphire.
i asked a few mates before an they gave me the rong ones no my head has lifted
My info lists different,
STAGE ONE 30-35NM
STAGE TWO 65-70NM
STAGE THREE ROTATE EXTRA 80-90 DEGREES.
I can't say which is right but mine taken form ford TIS DISC, if that's any help.
ps I double checked
STAGE ONE 30-35NM
STAGE TWO 65-70NM
ps I double checked
STAGE ONE 30-35NM
STAGE TWO 65-70NM
ps I double checked
STAGE ONE 30-35NM
STAGE TWO 65-70NM
ps I double checked
This info was on first one edition of "Technician Guide Ford Sierra RS Cosworth"
But, a Ford Campaign explain and change this procedure.
(Campagn C6CZ761 on june 1, 1987)
New procedure recommanded was as Cossiedavedree said.
This procedure is only with Ford OE head bolt. Not with ARP or with 12.9 bolt specification.
Regards.
Claude
im thick and dont understand a word you said lol
all i no is i brought the head bolts from pj's and need to no how to do them i will be doing them this week some time
You can use FORD HEAD bolts but ARP would be better, DO NOT USE THE ONES THAT CAME OUT, do not reuse, though I know others that have reused them as they have on zetecs!!
There seems to be a difference of opinion on the headbolt torques, so doing a bit of digging on this.
i will have to ask pj's then thanks anyway
witch headgasket is re-usable is it the group a one or the multi layer ceramic one??
so what was the out come of the tourqe setting? do you warm the enine up after stage 2 and then cool down an do a 80-90 turn? if so how do they build an engine on a bench and still get the right settings? could do with some help as i am about to remove my head , also in what order do you remove the bolts. cheers gary
Get a sierra pinto manual and use the same loosening tightening sequence.
NO warming of engine if it was it would blow as it is not tight yet!!
i did as you said an its ok thanks
Just to add to the confusion these figures are taken from the Cosworth workshop manual;
3 dr & 2wd Sapphire
Stage 1: 20 - 25 Nm
Stage 2: 45 - 50 Nm
Stage 3: rotate a further 170 to 180 degrees
4wd Sapphire & Escort (large turbo)
Stage 1: 45 - 50 Nm
Stage 2: rotate a further 180 degrees + or - 10
Stage 3: check for 110 Nm
Escort (small turbo)
Stage 1: 47 Nm
All figures are for oiled bolts.
3 dr & 2wd Sapphire
Stage 1: 20 - 25 Nm
Stage 2: 45 - 50 Nm
Stage 1: 45 - 50 Nm
Stage 1: 47 Nm
I think the later figures wouyld be safer as they hopefully would reflect any misjudgement on the original settings ?
I always check for final torque what ever ford say, but then I use ARP.
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
