What is needed for 19-20PSI Boost
Hi,i have here an Chip from an Escort Cosworth Gr.N Rallye car and light blue injectors. At the Escort the boost was round about 20PSI.
What have i to do do drive this boost at my 4x4 Saph..
which Mapsensor, Fuelpressure,...???
im a little unsure about the injectors...most people just go for greens.......you already have a fuel pressure regulator it is on the front of your injector rail...this will need the small bung removed off the top and adjusting(it is adjustable using a small allen key.)
the power can vary depending upon how the chip is mapped....my cosworth is peaking at 21psi and holds 20...it is running 341 bhp
i run a 3 bar map sensor
-31 actuator
803 green injectors.
t34 turbo
you will definately need this car setting up on a rolling road to ensure engine safety.....its all to easy to fit this yourself and wind up the boost
but you need to ensure correct fuelling if it is incorrect your engine will run lean on boost and you will melt a piston!!!
-31 actuator
t34 turbo
Are the 803 the green injectors?
The problem is, im from germany but have buyed the car from england.
In the car was this chip with light blue injectors.
Here in germany i know nobody who can read out the chip, the selle say it is from mountune but im not shure.
There is a sticker at the chip, van anyone tell me somthing about it if i make a photo of it?
I know the Chip is from our Escort Cosworth Rallyecar.
It was running with 19-20psi boost with ligt blue injector and a 3 Bar map.
It have ALS and i think a controll for waterinjection.
The seller of this car says the chip is from mountune, but im not shure that this is right.
Can anybody tell something about it?
[/img]
[/img]
CabrioTurbo
01-08-2015 11:04 AM
Escortdriver1
31-07-2015 02:36 PM
