2wd & 4x4 cosworth head!
Port design is the same, the 4x4 one is not stronger, but it does have more clearance around the top of the bolt holes so uses a larger clamp washer thereby distributing force over a larger area, when tightened up, which is obviously better.
As said early 2wd used a inbuilt damper protrusion(BOSS) on the heads whereas later ones did not .
Early 2wd heads had TWO holes for thermostat, later 2wd had 3 but still only used two, 4x4 always used all three.
09-10-2015 07:38 PM
rog
04-09-2015 12:10 PM
adam151082
11-08-2015 04:50 PM
