Help! Tachometer not working!
I have had a few where the needle sticks then if you tap the clocks it works ok for the rest of the day, I think this is common to have a few problems with them.
They can be fixed by SPEEDY CABLES, as I had one fixed and converted to read 8 cylinder for V8 engine in one.
look at the wires coming from the coil, the green one will go to very small resistor & is connectted by bullet connectors. remove the resistor & plug the two connectors together. this should cure it. think u can order a new resistor from ford but most people don't bother.
I tried to do as you wrote, but tachometer still not works....
PS: sorry for my english.
Souleyman,
Don't applogise for your english, I am sure it is a lot better than our russian!!.
It is good to have input from people in other countries anywhere they are, good on you I say.
Ive had this a few times over the years and it has always dry joints on the tacho pcb of the fords ive had.............
Have a look and see if you have any cracks in the solder.............
JK12
33
26-04-2021 12:09 PM
Rstar_man
143
20-07-2020 11:16 PM
