cts sensor on a 2wd sapph
23-03-2007, 06:27 PM
would tou use p.t.f.e tape around the threads to seal it?
23-03-2007, 06:39 PM
23-03-2007, 06:50 PM
Does not need it, if I remember right it has sealing wahser ?
I still used LOCTITE 5910 on the threads though!!
23-03-2007, 06:55 PM
if it has a sealing washer or an o-ring it shouldnt need anything at all,unless your reusing the old one
23-03-2007, 09:07 PM
The new sensor comes with the o ring on.
24-03-2007, 12:50 PM
cts
i have bought a new one, it has a washer on it... nothing special just a washer, but i don't trust it to seal! i'm replacing it cos i've had a bad missfire for a year now between 2 and 3000rpm on light throttle and this is my last port of call before i try getting a new ecu or pushing the old worth off a cliff!
24-03-2007, 01:13 PM
It will seal perfectly with this, just used this on some cars with no problems, no amount of pressure there anyway.
mark r
29-09-2015 07:27 PM
wheelwizardrefurbs
18-09-2015 08:59 PM
mike elsome
14-09-2015 04:08 PM
Si B
12-09-2015 06:49 AM
mike elsome
Ford Range
09-09-2015 05:05 PM
