split rims on a 3dr
split rims on a 3dr
first off id just like to say hello to every 1 as i am a new member and this is my 1st post.i have a 3dr cosworth and am looking for a set of 16' bbs or image dm split rims does any 1 know of any for sale or the correct offset any pics would also be nice
My BBS rims are 17" but tbh you aint gonna find another set of these in four stud easily. Image rims and BBS 16" splitties ocasionaly come up on ebay and on here but you have to be very quick off the mark to snap them up. Or buy them new off images web site??? My off set is et15 which fills out my arches very well.
Stu.
Stu.
My 16" BBS, not sure of the offset, but its no where near as low as 15! Probably 30, I run 225 on the rear with no rubbing but i have a bit of rubbing on the front with 205 tyres.
Leigh
Leigh
I have a set of Image ones, got them off Stucos above. I have just ordered some 7" inners for them to take them to 10.5J on the rear
Originally Posted by lamb chops
Leigh I have some 195/40 brand new continental tyres for the front of yours to stop it rubbing if your interested..
Leigh
cheers for the info i think il be getting some image dm's as i am never gong to get hold of a set of bbs. im guna fit 7.5'' at the front and 8.5'' at the rear that should fill the arches well
yeah you should be fine with those sizes as long as you get the right off set. Im running 9j on the rear and 8.5 on the front with the et15. Ive heard that image and compomotive have some caliper clearance problems if using large brakes (mine are reverse bolted so ive HUGE caliper clearance ) so bear this in mind before you buy.
Stu.
Stu.
So far, nothing. The actual arches are clearing, just. But ive yet to fit the body kit plastic arches....may need trimming but I can always play around with ride height as well. Front tyres are 215/40-17 so should be fine but rears are 235/40-17 so may have trouble with the rear spats.
Click the link and scan thru the pics and you'll see my wheels as they sit now before arches are on...
http://bbs.rsownersclub.co.uk/showthread.php?t=103652
My pet is Moonstone blue!
17"
The white on got (8*17) front and rear..
mine got 7,5*17 front and 9*17 rear!
The white one is the best looking 3door in norway!!
100% finnish all over!!!!!
NO its not a genuine RS500 engine!
Heisann!!
det er ikkje orginal rs500 motor osv..
Det er ein vanlig tredørs
men han har pussa opp å lakkert all plast, motor rummet og under bilen! Han har mattet ned heile bilen med 2000 papir å polert den opp!! den er som ett speil!!!!!
Det er ein ex bakkeløps motor! sjøl laga innsug, større bunnpanne, gjemte ledninger
i motor rummet.. alt er tatt!! den er heilt nyyydelig!!!!
eg håper å få han med på ford treffet til sommeren!
Har du fått på stripene nå??
Heisann!!
Høres rått ut! håper du får han med på teffet! er du klar med din til treffet?
Joda, har fått på stripene eg og, ble bra det! HAr også fått lakket plasten og mottorromet i vinter, men ikkje under så den i bildet er nok likevel hakket over min
LOL, it`s just a ferrytrip away so the old ford should make it!
When is the meeting at Rockinham? As you say, I`ll probaly rather bring my old mercedes
07-10-2015 12:56 PM
