actuator problem
actuator problem
Went to wind up my actuator (-31) for 15psi yesterday, only to find that there weren't enough threads left on the rod (4!) to wind it up, and when I tried winding it down to protect my turbo (after much 3-in-1 and WD40), the entire rod turned.
This is bad isn't it...
Entire rod is supposed to turn if not connected at turbine end and this is why it has a locknut to fix the two to each other, if it was fixed at actuator end to stop it turning and turbo end it would not need a locknut.
Originally Posted by tabetha
If the turbo cannot achieve 15 psi or thereabouts with -31 wound up maybe the seat is knackered or leaking ?
DavidK
27-09-2015 02:55 PM
Russ Payne
25-09-2015 08:29 PM
