Exsesive tyre wear!!!!!!!!!!
is exactly what i was thinkin when i took the wheel of, think the car will have 2 go in 4 trackin, the only other thing i can think is that the rear wheels have been swaped 4 the front at some point, havent had the tyres changed since i bought the car
As said really, crap camber does NOT CAUSE TYRE WEAR, bad toe does, on the rear as it toes OUT as std way too much, you can get plates to correct most of this for Ł10 a pair, couple of hours work to fit and job done.
Back in black!
Other way around matey, just look at early fiats/beemers some even with positive camber and still no inner wear.
The tyre can deform(fit) in relation to the road camber or such like but cannot do anything about being slid sideways across the road constantly, which it is doing with too much toe.
This is why when you buy a kit form R+B they go in the two REAR holes of the hub to counter toe as opposed to the top ones to counter camber.
TABETHA
TABETHA
I only have twenty five years, and can assure you what I say about the fitment of the rear shims is correct, you could always phone MIKE R on 01508 557822, to check ?
10 Years eh, you must be one of the new fangled fitters then ?
Since myself and my dad have fitted the shims to correct toe, we have not had to swap tyres round or have any wear out on inner edge.
You are welcome to do what you want and leave others to do what they want, there that is a happy compromise ?
Easy fellas, yer ive just bought some shims off mike but that not really going 2 help as the tyres pictured r fronts? thats why i thought it may b trackin, the only reason i said bout bck tyres is cause i aint sure if the wheels have ben swaped round at some point,
Thanx 4 all the advice though
07-10-2015 12:56 PM
