4x4 engine into 3dr cossie
ok im putting in my old engine out of my 4x4 sapphire into my 3dr.It be running rwd so ive got hold of most of bits i need ie 2wd sump,engine mounts,manifold etc.
also im transfering over my rad and 500 cooler from the sappy i was woundering can i still use all my 4x4 hoses ie boost/coolent/ancillary etc or would these have to be 2wd versions?
Originally Posted by jon@work
if you're using the 4x4 thermostat housing and water pump, then use the 4x4 water hoses
Cossiemodo
Originally Posted by The Beard
Originally Posted by RSCossieGaz
i be retaining them yes so it seems i can still use the original hoses
big_Rad
15-09-2017 09:36 AM
lockie
31-07-2015 10:03 PM
