Big disc kits? (budget)
Does anyone know if you can buy a big disc kit kit for a 2wd saff allowing you to retain the original 4-pots, cant afford the 2000 euro needed for a brembo/ap kit
Cheapest way is some FRS discs which are around 325mm, then get some brackets made by local engineering firm, and wider spacers for calipers to suit slightly wider discs, all in less than £100/150 for 325mm, BARGAIN.
jonfoc
16
11-09-2018 05:35 PM
