Polyurethane Exhaust Hangers
Location: Linlithgow and Drives a 1989 Flint Grey Sierra Cosworth
I have just fitted my exhaust up today. I have used some Poly hangers rather than the standard rubber items. I noticed that they now mount the exhaust firmly to the car.
Has anyone had problems if they have fitted these? Has the exhaust cracked or the brackets on the car broke?
Just it does seem tight, and the engine will move in relation to the car when its being driven so it could cause problems.
Thanks
Bruce
Thanks
Bruce
As in tight to the car body? if so it will vibrate of the floor, im sure your car didnt do this before, they will be alot tighter but if its touching the floor then its a no no
No mate, its not toughing the floor! lol
Its just the hangers are alot tighter than the standard rubber hangers. As in there is alot movement in the exhaust system, and i think it will put more stress on the joints or the exhaust in general.
Bruce
Bruce
My teacher told me that if you fitt a s/s exhaust, you should keep the standard rubber items. Because with the Poly hangers, the exhaust brackets could break.
Don't know if this is correct, but he said so.
Correct me if I'm wrong.
Greetz,
Greetz,
I fitted PU exhaust hangers and within a couple of weeks one of the exhaust brackets broke off
Doesn't leave much room for movement once fitted. I'm sure my exhaust manifold wasn't cracked before fitting these either
Pete.
Pete.
Exhaust Hangers
I fitted PU exhaust hangers to my 2wd saph with a mongoose ss system, shortly after the passengers side hanger snapped. Had a new bracket welded back on, went back to standard hangers all works well.
Hope this is of use.
Thanks guys,
Thats exactly what i thought would happen. I have allready taken them off. Need to go to ford and get some New rubber items now.
Bruce
Bruce
Out of interest, to all the people that have had brackets break, what exhausts are you using? What make of bushes are you using? Are the cars excessively low or stiff? Have they broke whilst conering fast etc?
Just curious really to see if its something else adding to the problem and not a problem with the bush itself.
My car is pretty low. Exhaust is Mongoose. Exhaust hangers are powerflex. Brackets were fine before these were fitted. It snapped off on a motorway journey. When i arrived at my destination the eaxhaust had melted a large part of my rear bumper - just to add insult to injury. God damn!
Pete.
Pete.
On here to much!!
Just posted same thing in Escos forum, was wanting to know the same as i heard that they can snap the brackets, just bought a full set for mine and dont want to start all that snapping carry on.
Originally Posted by JTECHSAFF
i run a mongoose and poly mounts and have never had a problem, holds the exhaust nice and tight ,doesnt rattle or touch anywhere
except trying to get them on and off!
Shit!
Just bought some deflex ones, for mine, Hopefully they'll be fine, as I have a problem with the exhaust moving around a hell of a lot.......
Worried now.
Worried now.
I bought the deflex ones mate. And they are way to stiff, thats why is asked this question.
See how yours are.
Bruce
See how yours are.
Bruce
I just brought a set of 3 Exhaust Hangers for my 2WD Sapphire.
Cheap as chips.
Here's the finis code if you need to buy some mate
Exhaust System Less Catalyst (Cosworth 2.0, 2WD)
Insulator - Rubber *Finis: 7131646
Cheap as chips.
Originally Posted by trevCOSS
gentlemen fit decent engine mounts
