Rear number plate holder
Stupid question realy but how do you remove the rear number plate holder on a 4x4 saph cossie as mine is cracked cheers
Mine was stuck on, really really stuck on, I removed screws thiking it was just these but no it had some super sticky pads so I just snapped it off, alright it snapped as I levered a bit too hard!!
Originally Posted by robbob
were is the other screws mate apart from the ones that hold the number plate on
Behind the piece of carpet where the jack is located you should find two oval black pieces of plastic either side with a bolt thread in the middle. You will need to squeeze the small tabs in on the ovals and push out as the number plate surrund is only push fitted on, be warned its a tight fit.
borboyous
22-08-2015 11:17 AM
