wide band lamba kit
wide band lamba kit
hi,
does anybdy know if you can run a innovate wideband lamba kit with a
level 8 ecu can it be link or is it a standalone system,i want to run it for
the logging and also it is able to run a closed loop setup,i cannot run
close loop on my level 8 because its moded to run 8 injectors.
Testing the future
good kits supposedly
you can use it in paralel with your L8 as a standalone system for logging and display.
sounds like you can't link it though. i am not totally familiar with the 8 injector software, but get in touch with RPLab (click link in my sig) and they should be able to help you out. they are absolute geniuses at the L8 and can do anything with it for the right price
You will need the following items from Innovate in order to log and display.
LC-1
XD-16 gauge (LC-1 and XD-16 do not log data)
DL-32 (Logs 5 external inputs or 5 internal)
LC-1
